Festool SYSROCK BR 10 DAB+ Worksite Radio
- Receives FM and DAB+ radio stations
- Bluetooth and AUX-IN interfaces
- Excellent sound in a compact and robust design
- Integrated USB interface for charging external devices
- Mains power or Festool Li-ion battery (10.8V to 18V slide-in battery packs)
- Perfect room-filling sound with 10W neodymium speakers
- Speakers and buttons protected to IPX3 standard
Compact, the SYSROCK BR 10 DAB+ can sit on the end of your bench or on a windowsill, on the ground, hung by its integral hook or mounted onto a tripod stand.
Rugged, it has a flexible and virtually unbreakable antenna and tough, anti-slip rubber bumpers for impact resistance. The SYSROCK BR 10 DAB+ produces excellent sound quality. Its neodymium speaker gives you up to 10W of clear sound. A Digital Sound Processor automatically adjusts lower frequencies relative to the volume. You can listen to DAB or FM radio, connect an MP3 player or use the Bluetooth option to listen to music from your phone.
The SYSROCK BR 10 DAB+ plugs directly into the mains or you can use a Festool Li-Ion slide-in battery pack battery, from 10.8V to 18V (the higher the battery voltage the better the sound quality). The backlit LCD clearly displays information stations (name, title, and elapsed time), the status of the battery and the operating mode. The speaker and the buttons have protection against splashes to IPX3 level. The SYSROCK BR 10 DAB+ will keep you company throughout the day. On site or in the workshop, a little music helps the day along with a smile.
Supplied with mains adaptor, auxiliary input cable and padded carry case (not compatible with the CXS and TXS battery packs).
