FISCH HSS Brad Point Drill Bit Hex Shank
- 1/4" Hex shanks for use in quick change chucks and keyless chucks
- High quality HSS brad point drills give clean, fast cuts every time
- Ground and manufactured from one piece for strength
Perfect for use in cordless drills and screwdrivers with 1/4" hex quick change chucks and offer a more secure fit in a keyless chuck. Made to a very high standard, these 1/4" hex shank brad point twist drills give exceptional clean cuts time after time. For strength, they are ground from a single piece of high speed steel. For a clean, fast cut, the centre point has two cutting edges and two spurs that scribe a very clean entrance hole. The specially ground flute with twin spiral lands quickly clears waste. Suitable for soft and hard woods, laminated boards, MDF and acrylic glass. 1/4" quick-change shank to DIN 3126.E6.3. Made in Austria.
