FISCH SP Brad Point Drill Bits
AX890587
AX890587
- SP Brad Point (AKA lip and spur) bits, precisely ground and sharpened
- Exact geometry for fast accurate drilling, made in Austria
- Available in a range of both metric and imperial sizes
Axminster Workshop Dowel Drill Stop Collar Set 3 (6, 8 & 10mm)From £2.48 £2.07
Axminster Workshop 13 Piece High Speed Steel Ground Drill Bit SetFrom £7.28 £6.07
Show more
Show less
These FISCH SP Brad Point or lip and spur bits are precisely ground and sharpened in Austria with the exact geometry needed for fast accurate drilling. Available in a range of both metric and imperial sizes suiting all types of timber.
N.B 3mm - 9mm have same shank as diameter, 10mm - 18mm have a 10mm shank, 20mm has a 13mm shank. 1/8", 3/16" and 1/4" have same shank as diameter.
