The DS400 is supplied with an easy-to-use single valve controlled RF80 torch which allows one-hand operation. Supplied with a solid refractory hearth with robust side and rear heat shields, the DS400 complies with British Gas standards and is a fully failsafe system. All sequences are visually displayed using neon indicators. On start-up the gas train, hoses and torches are tested for escaping gas. Leaks from any component will result in a continuously illuminated red neon and the main flow of gas will be prevented from entering the system.
