FlameFast DS400D Double Brazing Hearth
507118
From £7,476.48 £6,230.40
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Out of Stock
  • Supplied with 2 easy-to-use single valve controlled RF80 torches
  • Asbestos free heat resistant refractory hearth
  • Fitted with side and rear heat shields
  • Push button no volt release starter
  • Auto gas leak proving system on startup
  • Colour coded reinforced gas and air hoses
  • Push button electronic ignition
The DS400D is a double position brazing hearth, supplied with two easy-to-use single valve controlled RF80 torches which allow one hand operation. Equipped with a solid refractory hearth with robust side, central and rear heat shields.
The DS400D has a high safety rating and complies with British Gas standards and is a fully fail safe system. All sequences are visually displayed using neon indicators. On startup the gas train, hoses and torches are tested for escaping gas. Leaks from any component will result in a continuously illuminated red neon and the main flow of gas will be prevented from entering the system.
