Fuji Spray Semi-Pro2 HVLP Suction Spray System
501285
From £579.58 £482.98
10 Reviews
  • 1,400W, 2 stage turbine unit
  • Rugged all steel turbine cabinet with convenient carrying handle
  • High volume low pressure, minimal "bounce back", less wasted paint
  • 7.6m hose with Quick Coupling and Air Control Valve
  • Fuji Spray M-Model non-bleed gun, adjustable spray pattern, 1.3mm air cap
  • Range of optional air caps plus gravity cup kit, suits many applications
A flawless finish from Fuji
The Semi-PRO 2 System from Fuji Spray offers exceptional performance and versatility from an entry level HVLP spray system. Whether you’re a DIY-er or serious hobbyist, Fuji Spray has got you covered.
Whatever your application, the Fuji Spray Semi-PRO 2 will give you ultimate control, achieving a consistent and flawless finish.
  • Perfect for home, hobby and craft users
  • Powerful 1,400W 2-stage motor turbine
  • Lightweight and easy to use
  • Ergonomic spray gun handle offers comfort during long spraying sessions and is insulated to protect from heat
Gravity feed vs Suction feed
But the big question is, do you choose gravity or suction feed? The answer is usually down to personal preference, however, each has their own advantages.
Fuji Spray Semi-PRO 2 Gravity HVLP Spray System
With Fuji Spray M-Model 7002G Gravity Spray Gun and 400cc cup
Gravity fed guns rely on gravity, to feed the finish to the spray nozzle.
  • Good for smaller projects and touch up work
  • Are lighter and more manoeuvrable than suction type guns, great for inside cabinets or other fiddly tasks
  • Require less air pressure - making the gun more efficient, leading to less wastage and gives better control
Fuji Spray Semi-PRO 2 Suction HVLP Spray System
With Fuji Spray M-Model Suction Spray Gun and 1,000cc cup.
  • Suction feed guns can carry more fluid than gravity feed models
  • The Fuji Spray M-Series 7001 Suction Spray Gun has a non-bleed design with a fan control knob to adjust the spray pattern
  • They offer easy spraying with good coverage, and are suitable for a range of finishing applications
To meet the growing demands of the home, hobby and craft markets, Fuji has introduced the Semi-Pro2 HVLP spray system. Key features found on no other entry level system are standard, such as a powerful 1,400W 2-stage motor turbine and the Fuji Spray M-Model spray gun. This is a non-bleed design of gun with a fan control knob to adjust the spray pattern from small circular to a wide fan (and all increments in-between). Light in weight with a cool handle, this is supplied as a suction gun with a 1,000cc cup, but a smaller 400cc gravity cup kit can be purchased as an option. The nozzle and needle are stainless steel; other air caps are available as optional extras. The turbine unit is in a sturdy steel cabinet complete with a grab handle and handy gun storage. External air filters are easy to wash or change. Includes a full 7.6m hose with Quick Connect Coupler and an Air Control Valve. This is a lightweight machine ideally suited to serious DIY, crafts or hobbies. Supplied with comprehensive user manual, viscosity cup, cleaning brush and wrench. Everything except the paint!
Note: When spraying thick high gloss paints, the required thinning can affect the final finish. In this case we recommend using a 4 or 5 stage turbine unit; such as the Fuji Mini-Mite 4 or 5 or A Fuji Q4 or Q5 unit.
It is essential equipment is cleaned after every job and operating instructions are followed. Failure to do so will void warranty
Warranty 2 Year Warranty
4.90 10
