Fuji Spray Xpc Air Caps
AX810308
AX810308
- Sizes from 1.0mm to 2.2mm; for Xpc Spray gun only
- The smallest is suitable for inks, shading and mist coats
- The largest is great for spraying large surfaces
Show more
Show less
Fine 1mm (0.039") size Air cap Set for finer atomization. Suitable for most water-based lacquers and shading.
Standard 1.4mm (0.055") is installed in all Xpc spray guns. Air cap Set is perfect for most fine finishing.
High output 1.8mm (0.070") Air cap Set for faster coverage of large areas with any type of paint.
Extra high output 2.2mm (0.086"). Great for spraying large surfaces such as walls with emulsions. Expect some slight texture.
For G-Xpc spray gun only - does not fit older Fuji spray guns.
2 Year Warranty
