Axminster Professional Heavy Duty Roller Ball Stand
510407
Special Price £87.74 £73.12 was £109.68 £91.40 Save £21.94 £18.28
  5. Half Star
20 Reviews
In Stock - Ready to dispatch
  • Heavy duty roller/ball stand
  • Constructed from a combination of 50mm diameter round and square steel tubes
  • A choice of 330mm long by 60mm diameter roller (ball bearing mounted) or a row of 8 balls
  • Changeover from roller to balls takes seconds, no tools required
  • Roller height adjustable between 735mm to 1,120mm
  • Wedge lock for high stability under load
  • Unit folds flat for storage
The heavy duty roller/ball stand combines several outstanding features in one unit. Constructed from a combination of 50mm diameter round and square steel tubes, and has a choice of either 330 long by 60mm diameter roller (ball bearing mounted) or a row of 8 balls, to allow for all-round movement of sheet material. Roller height is adjustable over a range of 735mm to 1,120mm and the telescopic stem locks in position with a very solid knob. A unique wedge lock ensures the roller setting will not vary, making it suitable for heavy baulks of timber. The whole unit folds flat for storage. Maximum capacity 200kg.
4.70 20
