Hermes RB 377 YX Abrasive Belts 100 x 915mm
AX19640
AX19640
- Polyester/cotton cloth backed aluminium oxide abrasive
- High stock removal rates in the coarse grit range
- Consistent surface quality in the fine grit range
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £29.18 £24.32
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.18 £10.98
Axminster Professional Stainless Steel Metric Rule - 300mmFrom £8.28 £6.90
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)From £14.38 £11.98
Show more
Show less
To fit Axminster AS406/AS408/BD46, Perform CCBD46 and most other 4 x 6" belt/disc sanders. The polyester/cotton back combined with the resin bonded aluminium oxide grain mix produces a high stock removal with coarse grits, plus a consistent surface quality with fine grits. Smooth running and long lasting, perfect for abrading metals and sanding seasoned woods.
Abrasive Backing | Cloth |
Abrasive Belt Length | 915 mm |
Abrasive Belt Width | 100 mm |
Abrasive Type | RB 377 YX |
