Hermes BW 110 Abrasive Discs 305mm
- Aluminium oxide abrasive on heavy E-weight paper backing
- Semi-open coating, anti-static resin bonded reduces clogging
- Hook and loop backing for easy disc changes
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £29.18 £24.32
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.18 £10.98
A range of 305mm diameter hook and loop backed sanding discs suitable for the Axminster Trade SS-12VS, Jet JDS-12 and previous model Axminster DS12VEL disc sanders.
The aluminium oxide abrasive on an E-weight paper backing has a semi-open structure with antistatic properties to reduce clogging. BW110 is especially suited to sanding hardwoods and is suitable for use on metal. It has a good stock removal rate even with low sanding pressure. BW110 is an excellent multi-purpose abrasive for use with powered sanders.
Available in a variety of grits. Sold in singles.
Abrasive Backing | Paper and Hook and loop |
Abrasive Disc Diameter | 305 mm |
Abrasive Type | VC 153 VEL |
