Cabineo insert nut M6 x 12.3 for material 14 to 16mm thick, supplied in a pack of 100.
With the Cabineo 8 M6, connections can now be created with materials like aluminium, steel or HPL. However, where the thread cannot be cut directly into the substrate, Lamello offers an insert for an even stronger joint. This insert is ideal for detachable corner and dividing panel joints, and the installation of fixed shelves or vertical dividers in an already assembled unit. The insert allows easy disassembly and reassembly without loss of joint integrity.
The strength could also be further improved. The Lamello inserts are hammered into the dividing panels with a through hole, into which the Cabineo then engages from both sides. This generates an enormous clamping force.
Threaded inserts for material 14-16mm thick
Ideal for detachable corner and dividing panel joints
Easy disassembly and reassembly without loss of joint integrity
Use with Cabineo connectors for simple, fast and strong joints
