From £389.98 £324.98
Low Stock
  • RTJ400, designed specifically for router table use
  • Fast accurate routing of through and half blind dovetails and Box Joints
  • Precision CNC template and clamping fence
Customers Also Bought
Leigh's RTJ400 is designed specifically for router table use, offering fast accurate routing of through dovetails, box joints and half blind dovetails on your router table. The Leigh template is precision CNC machined from aircraft grade aluminium for perfect joinery every time.
The RTJ400 will make 9 sizes of through dovetails, 3 sizes of half-blind dovetails and 4 sizes of box joints. Set up is fast and simple with 5 instruction strips that guide you through set up and are located on the top of the jig giving you all the set up positions required. A perfect joint fit is guaranteed and repeatable with the patented Leigh e10 guide bushing with elliptical barrel that can be rotated for joint fit. Board alignment is done using the adjustable side stop with an offset for rebated half blind dovetails. The precision template and clamping frame can be aligned perfectly with clearly marked pin locators that are etched into the template.
9 sizes of through dovetail and 3 sizes half blind including half pitch. Dovetail board thickness: through dovetails 3.2mm (1/8")–25mm (1"), half blind 12.7mm (1/2")–25mm (1").
Box joints: 4 joint sizes 2.4mm (3/32"), 4.8mm (3/16"), 9.5mm (3/8"), 19mm (3/4"), board thickness 3.2mm (1/8")–25mm (1"). Please note, half-pitch through dovetails require an optional e7 guide bushing and optional 140-8 straight bit.
Supplied with blanking plates, stop rod, depth gauge,1/2" shank Dovetail bits: 80-500, 120-500, Straight bits 160 and 143-500, 4 cam speed clamps, hex key and adjustable side stop. Detailed instructional videos and comprehensive user guides are available online.
Note, For use with router tables that accept threaded guide bushes.
  • 9 sizes through dovetails, 3 sizes half blind dovetails
  • 4 sizes of box joints
  • Fast and simple with 5 on board instruction strips
  • Patented Leigh e10 elliptical guide bush rotates for joint fit
  • Board alignment using adjustable side stop with an offset available
  • Clearly marked pin locators that are etched into the template
  • Note, For use with router tables that accept threaded guide bushes
  • 4 x 1/2" shank cutters, speed clamps and blanking caps
  • Detailed instructional videos and comprehensive user guides are available online
Warranty Leigh 5 Year Warranty
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    3.90 8
