Axminster Workshop Light Duty Variable Height Extraction Hood
950030
From £32.98 £27.48
38 Reviews
  • For extracting waste from a dust source where direct connection to the machine is not possible or convenient
  • Adjustable in height from 750mm to 1,220mm
  • Tilting facility enables the collection slot to be positioned at the best possible angle
  • 100mm diameter hose connection
  • 320 x 35mm collection slot
  • Will not accept Big mouth dust hood (200114)
A simple dust extraction hood mounted on an adjustable height stand. Very useful for situations where direct connection to a machine is not possible, such as woodturning. Having a robust ABS hood fastened to a 100mm diameter metal tube, this is easily connected to flexible extraction hose leading from your extraction system. The steel stand gives a useful height range from 750-1,200mm and has 3 feet, so no wobbles on your uneven workshop floor! The hood has an inlet of 320 x 35mm creating a good airflow, an extractor of at least 750m3/hour is recommended. Will not accept Big mouth dust hood (200114)
3.80 38
