This kit is ideal for model making, intricate crafts, detailed renovation and restoration, electronics and other precision tasks.This Lightcraft magnifier kit is an essential piece of kit for close-up work. The lenses cover all focal lengths from quite close-up to very close-up. Head mounted it leaves both hands free.
The kit includes 5 interchangeable lenses with magnifications of 1.0x, 1.5x, 2.0x, 2.5x and 3.5x. The lenses clip into slots in the headband making changing from one to another quick and simple. The magnifier allows you to get comfortably close to the object you are working on allowing you to see the smallest detail. Designed for comfort and a secure fit, the side frames are adjustable. Also supplied with an alternative elastic headband to offer a more secure fit. A rechargeable LED spotlight provides greater clarity by illuminating the working area.
Supplied as a kit, includes a fully adjustable headband, 5 interchangeable optical lenses, built-in spotlight with protective case for the lenses, cleaning cloth and USB charging lead.
Magnification Working Distance
1.0x 250 to 350mm (10 - 14”)
1.5x 200 to 300mm (8 - 12”)
2.0x 175 to 275mm (7 - 11”)
2.5x 125 to 250mm (5 - 10”)
3.5x 75 to 125mm (3 -5”)
