Mafell Guide Rail - 800mm
107750
From £88.98 £74.15
1 Review
Out of Stock
  • Guaranteed zero-play guidance and tear-free cuts
  • Coated to help saw glide along smoothly
  • Straight as an arrow, even when extended
A Mafell saw and Guide Rail make cutting sheet material an absolute breeze. Combined with a Mafell saw the guide rail offers you dead-straight, tear-free cuts.
The Mafell F 80 800mm Guide Rail guarantees zero play guidance. The width of the guide rail supports the entire width of the saw. The upper side of the guide rail has a special coating helping your saw glide smoothly. On the underside of the rail two neoprene strips provide outstanding non-slip grip and protect the surface of the work.
The rubber edging strip minimises splintering on the top surface of the board. On the first cut the saw blade trims the strip, subsequently it acts as a guide showing you the exact cut line. The rails are easily extendable, a self-aligning joining piece ensures extended guide rails remain straight as an arrow. Removable end-caps prevent cables and suction hoses catching.
Using the optional Connecting Piece F-VS, the F 80 connects seamlessly with other F system rails as well as the Angle Fence F-WA
5.00 1
