Marxman Pen Standard Hole Marking Tool
- Featured on Dragon's Den, multi award winning
- Marxman is a unique marking tool
- Produces a clear reference mark, quickly and easily
- Highly visible, fluorescent green pigment
- Works on most surfaces from glazed tiles to pebbledash
- Marks through thickness up to 45mm
- Each Marxman dispenses 250 doses
- Solvent-free and non-permanent
- Manufactured in the UK
Featured on Dragon's Den, this multi award winning, simple solution solves a very common problem. It’s one of those “now why didn’t I think of that” ideas.
For instance, you need to fix a thick pre-drilled batten onto a wall, how do you go about marking the holes for the fixings? Do you sharpen your pencil, scratch around for a slimline felt tip pen, or try to find a bradawl with a long enough blade? When you remove the batten and prepare to drill, can you clearly see the marks?
The Marxman Marking tool is a unique tool, enabling you to make a clear reference mark, quickly and easily. It works on just about any surface; tiles, pebbledash, plasterboard, wood, block-work, cement, even oily metal. Simply push Marxman into a fixing hole and it delivers a burst of bright, fluorescent green pigment, onto the mounting surface. The pigment is highly visible, solvent-free and non-permanent and clearly shows you exactly where you need to drill. The ease and accuracy, saves you time and frustration every time. The Marxman is particularly useful if fixing at height. You can use one handed, whist holding an item in place with your free hand. It marks through thickness up to 45mm each Marxman dispenses 250 doses.
Manufactured in the UK.
