Mirka Carat Flex Abrasive Roll 115mm x 5m
- Excellent general purpose abrasive for a range of applications
- A stearate coated abrasive with a long lifespan
- For hand sanding many surfaces and materials
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £30.28 £25.23
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.68 £11.40
A stearate coated abrasive for dry sanding applications, Carat Flex features fine stock removal with a uniform scratch pattern, a long lifespan and extremely good grain adherence. The stearate coating helps prevent the sanded off residue from adhering to the abrasive, extending it's life. The backing consists of a flexible, impregnated latex paper which is ideal for profile sanding. Used for hand sanding wood, sealers, lacquers and paints.
Abrasive Backing | Paper |
Abrasive Material | Silicon Carbide |
Abrasive Roll Width | 115 mm |
Abrasive Type | Carat |
