Numatic WV 380-2 Wet & Dry Vacuum Cleaner
- Industrial wet or dry vacuum
- 1,200W bypass motor
- Supplied with float valve for automatic shut off when full of liquid
- Excellent dry performance
- Heavy duty Structofoam body
- 15 litres dry / 9 litres wet capacity
- Four castors on base for mobility and stability
- Full wet and dry tool kit included
The WV-380s are, by design, wet or dry vacuum cleaners that perform totally without compromise in either mode. When you want to operate as a dry machine performance must be as good as a dry-only machine, with big filters and the option of giant HepaFlo disposable dust bags ensuring a high standard of operation. Similarly, when required for wet work, a quick switch of the dry filter for the wet float valve and a change of floor nozzle will give you equally professional performance and a clean, dry floor at the end of it all. Extremely ruggedly built, with Numatic's patented Structofoam container and amply powered by a 1,200W "Twinflo" motor.
Supplied with Numatic AA12 Aluminium MultiFlo 32mm Accessory Kit which includes 2.4m Nuflex hose, aluminium extension tubes, dry nozzle and wet pick up nozzle.
Airflow Volume | 2,700 litre/min |
Cable Length | 10 m |
Corded or Cordless | Corded |
EAN Barcode | 5028965246078 |
Max Capacity Dry | 15 litre |
Max Capacity Wet | 9 litre |
Model | WV 380-2 |
Motor Power | 1,200 W |
Nett Weight | 8.6 kg |
Overall L x W x H | 355 mm x 355 mm x 510 mm |
Rating | Trade/Professional |
Sound Pressure Level LpA [Uncertainty K] | 77 dB(A) [0.2 dB] |
Suction | 23.5 kPa |
Voltage | 230 V |
