Pegas Super Skip Scroll Saw Blades
- Made in Switzerland from heat treated high carbon steel
- Perfect for intricate fret work - the higher the tpi, the finer the cut
- Best performance in hard woods
- Blade length 130mm
- Pack of 12
Super skip tooth blades are versatile, performing well in wood, plastic, bone, Corian® and most fibrous materials. These blades offer an exceptionally clean cut for intricate fret work - the higher the tpi number, the finer the cut that can be made. These blades are especially good for hardwoods. Thickness of work ranges from 1.5mm to 60mm. Overall blade length 130mm.
