PROXXON 1/2" Drive MICRO Compact Ratchet
107388
From £22.78 £18.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Out of Stock
  • 1/2" square drive with an extremely slim head
  • Enables work in places where space is tight
  • Fine 72-tooth ratchet allows movement in narrowest spots
  • Strong CrV steel forging
  • Double nickel-plated with matt chrome plated finish
  • Oil and acid resistant thermoplastic rubber grip
  • Push button release to unlock sockets
The PROXXON MICRO compact ratchet is an industrial quality ratchet designed for professional use. Having 1/2" square drive with an extremely slim head only 34 x 17mm and overall length of 195mm, it enables you to work in places where space is tight. The fine 72-tooth ratchet allows movement in the narrowest spots and is capable of transferring high torque. The head has a release mechanism, which unlocks sockets at the push of a button. Double nickel-plating and a matt chrome plated finish give the CrV steel forging maximum protection. The grip is an oil and acid resistant TPR (thermoplastic rubber) with a practical hanging hole.
