PROXXON Battery-Powered Belt Sander BS/A
- Perfect for intricate jobs, delicate finishing or refining
- 10mm wide sanding belt, 110mm arm length
- Head angle changed at the touch of a button
- 10.8V (2.6Ah) lithium-ion battery for mains comparable performance
- Die-cast aluminium head ensures long, trouble-free working life
- Comfort grip for greater control
- Supplied in tough case, with 4 sanding belts (2 x 80g, 2 x 180g)
This quality, cordless industrial power tool is ideal for grinding of small openings, finishing of moulds, surfaces, radii, grooving, deburring and chamfering of precision parts. You can change the angle between the head and the body at the touch of a button by 60° for better access. Changing the sanding belt takes only a few seconds. The BS/A has a vacuum connection for clean working. This professional quality battery-powered MICROMOT tool combines the features of its mains equivalent with the convenience of a cordless tool. The 10.8V, 2.6Ah lithium-ion battery gives a performance comparable to its mains-powered counterpart. The main bearings and gears sit in a die-cast aluminium head ensuring a long, trouble-free working life. The glass fibre reinforced POLYAMIDE main body houses a special balanced, powerful, quiet and long lasting DC motor. The soft component body grip offers comfort and greater control. The flat end cap on the battery enables the tool stand upright when not in use. Overall length 380mm. Complete with four sanding belts (two pieces each of grit 80 and grit 180), lithium-ion battery (10.8 V), fast charger and virtually unbreakable polypropylene case.
Abrasive Belt Size | 10 mm x 330 mm |
Batteries Included | 1 |
Battery Capacity | 2.6 Ah |
Battery Type | Li-ion |
Battery Voltage | 10.8 V |
Belt Speed | 200 to 700 m/min |
Charge Time | 60 minutes |
Corded or Cordless | Cordless |
EAN Barcode | 4006274298101 |
Model | BS/A |
Nett Weight | 0.9 kg |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 103 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 90 dB(A) [3.0 dB] |
