This quality, cordless industrial power tool is ideal for the grinding of small openings, finishing of moulds, surfaces, radii, grooving, deburring and chamfering of precision parts. You can change the angle between the head and the body at the touch of a button by 60° for better access. Changing the sanding belt takes only a few seconds. The BS/A has a vacuum connection for clean working. This professional quality battery-powered MICROMOT tool combines the features of the mains equivalent with the convenience of a cordless tool. The main bearings and gears sit in a die-cast aluminium head ensuring a long, trouble-free working life. The glass fibre reinforced POLYAMIDE main body houses a special balanced, powerful, quiet and long lasting DC motor. The soft component body grip offers comfort and greater control. Belt size 10 x 330mm. This is a body only tool supplied without batteries or charger.
