The Proxxon IGS/A industrial straight grinder when fitted with a battery offers you performance easily comparable to its mains-powered cousin. Built to last; the gear head is die-cast aluminium and the main body housing is glass-fibre reinforced POLYAMIDE. The soft grip insert offers comfort and improves control.
The IGS/A features a continuously variable speed control (1,500 - 4,200 rpm) with a special balanced DC motor giving plenty of power at low speeds. The specifications and features mean this tool can be used for a myriad of tasks such as brushing, grinding, frosting, deburring, paint stripping and more. The compact design and lightweight (970g) make the IGS/A very easy to handle compared to standard size grinders. It comes with an industrial keyed drill chuck with a capacity from 0.5 to 6.5mm.
Note this is a body only tool supplied with a 50mm wire brush in a cardboard box without battery or charger.
