PROXXON KS 230 Saw & HSS Fine Blade for KS230E - PACKAGE DEAL
717493
717493
From £129.98 £108.32
  5. Half Star
12 Reviews
Low Stock - Ready to dispatch
  • PROXXON KS 230 Saw
  • 8mm depth of cut
  • 58 x 10mm saw blade
  • Fully machined aluminium table
  • Sturdy ABS base
  • Mitre fence and rip fence
  • 34mm diameter dust extraction port
  • PROXXON HSS Fine Blade for KS230E
  • Blade for the PROXXON KS 230E saw
  • 50mm diameter spring steel saw blade(10mm bore)
Package deal comprises the PROXXON KS 230 Saw and the PROXXON HSS Fine Blade for KS230E.
PROXXON KS 230 Saw
A small precise mains driven modelling saw with an 8mm depth of cut using the standard 58mm diameter blade. It has a fully machined aluminium table top some 160 x 160mm mounted on a sturdy ABS base, and comes with a mitre fence and rip fence. There are 2 blades available for different materials, the 300108 alternating set for wood and plastics and the 300109 for fine cuts. There is a 34mm diameter dust extraction port at the rear of the machine.
50mm diameter Spring Steel Saw Blade(10mm bore). Designed with fine teeth for precision cutting.
4.60 12
