PROXXON MICROMOT 230/E Mill/Drill Set
107275
From £104.98 £87.48
1 Review
Low Stock - Ready to dispatch
  • Slim body, easy to handle and control
  • Light weight only 270g
  • Variable speed with electronic feedback
  • Quiet, balanced, long lasting DC motor
  • Comes with 6 high quality steel collets
  • Supplied in case with 34 bits and cutters
Perfectly precise with PROXXON
- The 20mm Collar System
The 20mm collar range of PROXXON tools allows you to easily connect to one another and achieve maximum precision and versatility with your intricate tasks. Simply clamp the collar of your PROXXON drill or grinder to the drill stand, universal holder or router base and your tool is held steady whilst allowing you to take on a range of tasks including routing, engraving and drilling.
PROXXON Micromot Mb 200 Drill Stand
Enables bevelled drilling and versatile milling operations.
PROXXON MS 4 Machine Vice
Use with the drill stand.
PROXXON UHZ Universal Holder
Keep your tool stationary whilst you maneuver what you are working on.
PROXXON Router Base OFV
For slotting, milling grooves and milling edges.
The MICROMOT 230/E has a slim housing, only 37mm, and a soft comfort grip area giving it excellent controllability and easy handling with a two fingered pen grip.
It has a quiet and extremely long-lasting balanced DC motor with electronic speed control for speeds from 6,000 to 22,000rpm.
The MICROMOT 230/E lets you drill, mill, grind, polish, brush, cut and engrave. It comes with a set of six MICROMOT steel collets ensuring even the smallest shafts are accurately clamped. No rattling or vibrating of bits and cutters. The 20mm standard collar allows its use with MICROMOT drill stands and horizontal stands.
This kit includes 34 industrial quality bits and cutters, 6 MICROMOT steel collets (1 each of 1 - 1.5 - 2 - 2.4 - 3 and 3.2mm). Everything finds its place in the robust storage case.
Warranty 2 Year Warranty
5.00 1
