PROXXON Mill/Drill 230/E, Modeller's Set & Drill Set - PACKAGE DEAL
717735
717735
From £101.47 £84.56
  • PROXXON Mill/Drill MICROMOT 230/E
  • Slim, easily handled and light weight (270g)
  • Variable speed with feedback
  • Special balanced, low noise DC motor
  • Supplied with 6 collets
  • PROXXON 13 Piece Modeller's Set
  • For cutting, milling and drilling
  • 2 fine cylindrical milling bits 2.3 mm diameter
  • 2 carborundum grinding bits (ball and cone)
  • 1.0 and 2.3 mm micro drills
  • 1 saw blade 22mm dia.
  • 5 cutting discs 22mm dia.
  • 1 arbor
  • All shafts 2.35mm
  • PROXXON 6 Piece HSS Twist Drill Set
  • HSS twist drill set with centring point
  • 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm
  • Titanium coated for long life
  • 3mm shanks
  • Show More
This package comprises the PROXXON Mill/Drill MICROMOT 230/E, 13 Piece Modeller's Set and the 6 Piece HSS Twist Drill Set.
The MICROMOT 230/E is designed for drilling, milling, grinding, polishing, brushing, cutting and engraving. The extremely slim housing of glass-fibre reinforced POLYAMIDE with a soft component grip area enables the unit to be handled with two fingers (pen grip). The maximum speed of 21,500rpm can be continuously reduced to 6,500rpm through full-wave electronics. This tool offers nearly the same torque in the lower speed range. This is especially important for micro-drilling, brushing and polishing. Ground, ball-bearing spindle. High quality MICROMOT steel collets.
For cutting, milling, polishing and drilling. Two fine cylindrical milling bits 2.3mm diameter, two carborundum grinding bits (ball and cone), 1.0 and 2.3mm micro drills. One saw blade of 22mm diameter, five cutting discs of 22mm diameter and one arbor. All shafts 2.35mm.
A HSS twist drill set with centring point, sizes: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm. Use for precision drilling in wood, plastic non-ferrous metals, steel and stainless steel sheets. The titanium coating reduces friction and increases life expectancy. Shanks 3mm - 6 pieces.
5.00 1
