PROXXON MP 400 Micro Shaper & Set of 10 Wood Router Bits - PACKAGE DEAL
717494
717494
From £219.98 £183.32
4 Reviews
Low Stock - Ready to dispatch
  • PROXXON MP 400 Micro Shaper
  • Self contained unit using miniature router cutters
  • Designed to produce small detailed profiles used in dolls house and model making projects
  • Head is fully adjustable within a cutter guard
  • Comes with adjustable fence and mitre fence, plus 2.4, 3 & 3.2mm collets and tools
  • PROXXON Wood Router Bits - Set of 10
  • Molybdenum-chrome Vanadium steel
  • 10 piece set or available individually
  • 3.2mm shanks
  • Straight, veining, beading, vee groove, guided beading, guided cove and guided rebate cutters
Package deal comprises the PROXXON MP 400 Micro Shaper and the PROXXON Wood Router Bits - Set of 10.
A cross between a router table and moulder/shaper in miniature. This machine is a self-contained unit using miniature router cutters, held in the collets 2.4, 3, and 3.2mm, to produce small detailed profiles used in dolls house, model making projects and similar precision work. Powered by a long-life 100W motor achieving 25,000rpm no load speed. The head is fully adjustable within a cutter guard/hold down, the incremental adjustment can be zeroed with one revolution equalling 1.00mm in height and one division on the scale equalling 0.05mm in height. Measuring 300 x 150mm the table is a generous well made surface supporting a full length parallel fence and slotted for the mitre fence or any jigs or sub-tables you might want to traverse across the cutter. Dust extraction is essential with this unit via the 37mm outlet provided and which is suitable for connection to a standard vacuum cleaner.
Molybdenum-chrome Vanadium steel router bits with 3.2mm shanks. A set of 10 consisting of: 3.2mm, 5mm, 6.5mm straight, 3.2mm radius veining, 3mm radius beading, 6.5mm vee groove, 2.4mm guided beading, 3.2mm guided beading, 4.8mm guided cove and 3.3mm guided rebate cutter. Also available individually.
4.80 4
