Shokunin Blade for Japanese Dozuki Saw - 240mm
105012
From £27.88 £23.23
1 Review
In Stock - Ready to dispatch
  • Replacement or spare Japanese saw blade
  • 0.3mm thick with fine pitch crosscutting teeth
  • Easy change, single screw fixing
A replacement or spare blade for the Shokunin 240mm Dozuki Japanese saw. The blade thickness is only 0.3mm and tooth pitch of 1mm; it cuts smoothly and with great ease. The nickel plating protects against corrosion and prevents resin build-up. Easily changed by simply loosening the locking screw on the handle, remove the old blade and replace it with the new.
5.00 1
