Tite-Fix Screw-Tite Yellow Pozidrive Countersunk Screws
- Tri-lock TS Threadform for an immediate start
- Tri-lock shank means there is 25% less insertion torque
- High-quality pozi, multipurpose screw
- For use in a large range materials without the need to pilot hole in most cases
- Double countersunk head ensures a clean, flush finish
Axminster Professional Ductile Cast F Clamp 200 x 100mmFrom £21.28 £17.73
Axminster Professional Alloy Bar Clamp/Spreader 150 x 80mmFrom £18.68 £15.57
Axminster Workshop 6 Piece Tapered Drill & Countersink Bit SetFrom £26.28 £21.90
Tite-Fix Screw-Tite pozi screws are the fixing for you if you want a guaranteed, high-quality finish. These multipurpose, advanced screws have a unique Tri-Lock TS Threadform which joins together the benefits of a single thread and twin thread in one screw. You will get a balanced, immediate start with a fast insertion leaving you with a firm fix. The tri-lock shank ensures there is 25% less insertion torque, so your timber will not receive any damage. Screw-Tite screws can be driven into a large range of materials including hardwood, softwood, masonry, sheet steel, plastic and more without the need to drill pilot holes in most cases. The double-countersunk head means you will achieve a clean, flush finish every time. These screws have a PZ recess.
Please note, a pilot hole is needed when using masonry.
Drive Type | Pozi |
