Tormek T-4 Original Sharpening System With HTK-806 Hand Tool & TNT-808 Woodturner's Kits
- Tormek T-4 Water Cooled Sharpening System
- Compact, high quality sharpening system
- Perfect for sharpening hand tools, knives, woodturning tools etc
Customers Also Bought
Tormek T-4 Water Cooled Sharpening System with NVR Switch, Tormek HTK-806 Hand Tool Kit and Tormek TNT-808 Woodturner's Accessory Kit.
the Tormek T-4 features a zinc cast top incorporating the machine's key components: the main shaft, Universal Support and motor assembly, which results in superb accuracy. Two sleeves hold the Universal Support in the zinc cast top, this along with the locking device and tight tolerances guarantees perfect results every time.
The T-4 is ideal for sharpening cabinetmaking hand tools, knives, scissors and woodcarving and turning tools. It comes supplied with two useful accessories, the first of which is the SP-650 Stone Grader which can be used to keep the stone cutting efficiently as well as changing the surface from a (220g) coarse cut to (1,000g) fine. The equivalent of 2,500-3,000g can be achieved on the leather wheel. The second is the AngleMaster, an adjustable device used to set the correct angle for grinding plane and chisel blades. Magnets on the reverse side of the AngleMaster mean that it is easy to store it conveniently on the steel machine plate.
Also supplied is the unique Tormek Handbook, where all the information that is required to shape, sharpen and hone your tools to perfection can be found. The T-4 uses a powerful, industrial AC motor and the shaft supporting the wheels is made from corrosion resistant stainless steel. It also includes the Tormek Handbook.
New 8 year warranty (5+3)
Introducing the new Tormek T-4 Original extended warranty of 5 years + 3 extra years upon registration.
Packed in a high quality storage case with an opaque lid and foam insert the HTK-806 is a comprehensive kit of 6 jigs for sharpening common hand tools. The jigs enable you to sharpen a wide range of tools such as axes, scissors, long chef’s knives, short bladed knives, carving and butt chisels, pocket knives and garden shears.
The Tormek HTK-806 contains the following Tormek jigs: SVM-45 Short Knife Jig, SVM-140 Long Thin Knife Jig, SVX-150 Scissor Jig, SVS-38 Short Tool Jig, SVA-170 Axe Grinding Kit and SVM-00 Small Knife Holder.
Packed in a second high quality storage case, the TNT-708 is a comprehensive woodturner's sharpening jig set. The TNT-708 innovative Tormek tool set for woodturners contains everything you need to shape and sharpen all turning tools. The jigs give you complete control over the sharpening process. The jigs ensure you are able to reproduce and repeat your preferred bevel angles and tip profiles time after time.
The Tormek TNT-708 set includes the following Tormek jigs and accessories: SVD-186 Universal Gouge Jig, SVS-50 Multi-Jig, SVD-110 Torlock Tool Rest, TTS-100 Angle and Setting Gauge, LA-120 Honing Wheel, MH-380 Protective Cover, and tuition manual.
For more tips on sharpening please see Tormeks YouTube channel.
- 200mm diameter stone with stainless steel shaft
- Compatible with a huge range of Tormek jigs
- Strengthened housing for improved sharpening results
- Solid zinc, precision machined top incorporating the handle
- SP-650 Stone Grader and AngleMaster included
- New 8 year warranty (5+3)
- Tormek HTK-806 Hand Tool Kit
- Kit contains:
- SVM-45 Short knife jig
- SVM-140 Long thin knife jig
- SVX-150 Scissor jig
- SVS-32 Short tool jig
- SVA-170 Axe grinding kit
- SVM-00 Small Knife Holder
- All contained in a quality storage case
- Tormek TNT-808 Woodturner's Accessory Kit
- Kit contains:-
- SVD-186 Universal Gouge Jig
- SVS-50 Multi jig
- SVD-110 Torlock Toolrest
- TTS-100 Turning Tool Setter
- LA-120 Honing Wheel
- MH-380 Protective Cover
- Tuition manual
- Includes quality storage case
