TSO Festool Guide Rail Extension & Connectors GRE-13
- Guide rail extension to add length to your existing guide rail
- Achieve straight, accurate cuts
- Ideal for use at both the start or end of your cut
- Securely attach the extension with the GRC-12 self aligning connectors
- An excellent solution to those who require additional length
- Compatible with all Festool guide rails
TSO Products GRS-16 PE v2 Parallel Edge Guide Rail AdaptorFrom £144.88 £120.73
This TSO 346mm Festool Guide Rail Extension is perfect for when working on sheet materials, where the 1,400mm guide rail is not long enough to guide the saw from start to finish. Ideal for use at the start or at the end of your cut, simply join the extender to your existing guide rail and secure with the GRC-12 self-aligning guide rail connectors. Secure the extension down using a 3mm driver or hex wrench. It provides an excellent solution to those who require additional length, without purchasing a full-length rail and will ensure straight, accurate cuts every time. Plus, this TSO Festool Guide Rail Extension fits perfectly inside a systainer for effective transporting. Compatible with all Festool guide rails.
Supplied with 346mm Festool Guide Rail and GRC-12 self-aligning guide rail connectors (pair).
EAN Barcode | 859448007801 |
Model | GRE-13 |
Rating | Trade/Professional |
