TSO Triangle to Guide Rail Adapter 61-525
- Adaptor for MTR-18 or PTR-18 precision triangles
- Transform precision triangle into large, variable angle guide rail squares
- Quick and easy set up
- Compatible with a range of guide rails
The TSO Triangle to Guide Rail adaptor is an accessory that transforms precision triangles into large, variable angle guide rail squares. If you own a MTR-18 or PTR-18 TSO precision triangle, the adaptor allows you to connect it to guide rails made by Festool, Makita, Milwaukee, Kreg, WEN, RIDGID and Powertec.
Simply attach the adaptor to your triangle using the tapped accessory mounting holes. Loosen the two hex screws so the torpedo nut can be slid into the T-slot and slide onto your guide rail's top-mounted T-track. Position at your desired point and secure using the hex screws.
Supplied with triangle adaptor, torpedo nut with keystone alignment feature, x2 M6 x 1.0 hex screws, x2 M5 x 0.8 flathead socket cap screws.
EAN Barcode | 850043733171 |
Model | 61-525 |
