From £199.98 £166.65
  • Build a portable workstation, replacement MFT (multifunction table) top or multiple cutting boards
  • Make a simple configuration in thirty minutes or less
  • Produces a precise pattern of 20mm holes and guarantees perfect 45° and 90° cuts, every time
Customers Also Bought
A new way of working
An invaluable tool for professional trades and home workshops alike. If you are looking to build a custom bench top, a portable cutting board or a replacement MFT top, with the UJK Parf Mk II Guide System, you can do all of this and more. The versatile jig system allows you to make a simple configuration in less than 30 minutes, whenever the need arises. The Mk II guarantees drilling accuracy overtime. It allows you to create a tighter grid format at 32mm or 46mm spacing giving you more options when cutting, assembling or clamping. It's also supplied with a Centrotec bit holder for your 3mm drill bit resulting in easier operation.
Simple to use and reliable
Every woodworker strives to achieve consistent right-angled cuts, but it's not just an accessory for track saws...
Create a cutting and workholding workstation
Based on Pythagoras’ theorem, the UJK Parf Mk II Guide System helps to produce benchtops with an accurate pattern of 20mm holes. You can also create a quick, simple configuration in 30 minutes or less.
When used with a set of UJK Super Dogs, a guide rail and a track saw, it guarantees perfect, quick and easy 45° and 90° cuts every time. You can even cut large sheets. It offers the base for many work holding solutions with the addition of optional UJK dogs, cams, wedges and fences!
This is how easy it is
Watch our short video, it gives a great insight into the process!
The system uses two Parf Sticks along with a drill guide and a special 3mm drill bit to create rows and columns of holes at perfect right angles. The drill bits are suitable for all 1/4" hex quick change systems including the Festool CENTROTEC.
Read our full article
What's in the kit?
  • 2 x 1m long Parf sticks
  • 2 x drill guides
  • 3mm drill bit
  • 20mm drill bit with 3mm centre guide
  • 3 x guide pins
  • Guide block
  • 2 x low profile dogs
  • Extractor outlet
UJK and Parf
A collaboration between Axminster Tools and Peter Parfitt, the UJK Parf Guide System has been developed under the UJK brand. The design preserves and guarantees the long-term accuracy of the jig as well as improving the ease of use.
With a focus on British manufacturing, the vast majority of UJK products are proudly designed, developed and manufactured here in Axminster, Devon. The ever-growing range of unique products offer what woodworkers want and need. Explore the full range...
Axminster recommends
The range of UJK accessories is designed to further enhance your cutting and work holding
Dogs
Precisely manufactured to fit 20mm holes. Combine with other accessories for cutting and work holding versatility!
Rail Clips
The perfect accessory for track saw users! Secure your Festool or Makita rails and achieve complete accuracy.
Repeat Stop
Make accurate repeat cuts to the same length with ease.
Surface Cam Clamps
Solves the problem of holding an item on a flat surface using only side pressure.
Wedges
Using two wedges acting against each other ensures the applied force is at 90° to the edge of the workpiece.
Assembly Square
An excellent assembly aid for box, frame or carcass construction.
Fence & Stop Kit
Remove the need to reposition Dogs when cutting different lengths. The stop allows accurate repeat cuts.
Accessory Kits
Great value kits offering the most popular work holding accessories.
Do you want to create a custom-made bench top? Or a portable cutting board? Perhaps a replacement MFT top? With the UJK Parf Mk II Guide System, you can do all of this and more. The versatile jig system allows you to make a simple configuration in less than 30 minutes whenever the need arises. It may appear complicated at first sight; in reality, it is quite straightforward with highly accurate results easily achievable.
Based on Pythagoras' theorem, it guarantees accuracy and eliminates any chance of cumulative error. It helps produce a bench top with a truly accurate pattern of 20mm holes. When used with a set of UJK Super Dogs, a guide rail and a track saw, it guarantees perfect, quick and easy 45° and 90° cuts every time. The UJK Parf Mk II Guide System is an invaluable tool for professional trades and home workshops.
The MK II guarantees drilling accuracy overtime. It allows you to create a tighter grid format at 32mm or 48mm spacing giving you more options when cutting, assembling or clamping. It's also supplied with a centrotec bit holder for your 3mm drill bit resulting in easier operation.
Most importantly accuracy is assured and this jig will not allow for cumulative errors due to the way it works.
The design of the UJK Parf Mk II Guide System preserves and guarantees the long-term accuracy of the jig as well as improving the ease of use.
The Parf Mk II Guide System uses 2 x Mk II Parf sticks along with a drill guide and a special 3mm drill bit to create rows and columns of holes at perfect right angles.
The accuracy of the system is dependent on the very tight tolerance of the holes in the Parf stick. The Mk II drill guides locate positively into holes in the UJK Mk II Parf Stick. The guides feature an oilite bush to guide the Mk II 3mm drill bit. This design prevents any possibility of wear or elongation of these vital holes as a result of repeated use. Additional holes in the Mk II sticks offer the possibility of drilling intermediate holes at 32mm or 48mm centres or holes at predetermined angles other than 90°. The Parf sticks have a metric scale along one edge so that they may have other uses in the workshop.
Once the pattern of 3mm holes is complete, use the Parf guide block and 20mm boring bit to enlarge the holes and your bench top is finished and ready to take bench dogs.
The complete UJK Parf Mk II Guide System comprises 2 x 1m long Mk II Parf sticks, with holes along their length at 96mm centres; 2 x Mk II drill guides, a Mk II 3mm drill bit and 3 x Mk II guide pins. An extractor outlet, guide block, along with a pair of UJK low profile dogs and a special 20mm TC drill bit with a 3mm centre guide are also included. Please note: 3/4" cutter is not available.
The UJK Parf Mk II Guide System is a collaboration between Axminster Tools and Peter Parfitt. Manufacturing of the system takes place entirely in Axminster, Devon under the UJK brand name.
The UJK Chamfer Ring© is the intellectual property of Axminster Tools Ltd. Any infringement is strictly prohibited.
  • Based on the Pythagoras' theorem for infallible accuracy
  • Guarantees accuracy and eliminates any chance of cumulative error
  • Use with a host of 20mm dog fitting and accessories
  • Straightforward to use, for a host of guiding and clamping tasks
  • Guaranteed long-term accuracy for professional and home workshops
  • All components made, checked or assembled in Axminster for UJK
  • Developed by UJK and Peter Parfitt, a joint development with Axminster Tools
Made in Britain Made in Britain
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    4.80 430
