Veritas Box-Maker’s Plough Plane
From £165.68 £138.07
  • Small joinery plane, perfect for cutting drawer and box bottoms
  • Excels at cutting grooves, rebates and decorative beads
  • Comfortable to hold with a nice weight and balance
  • Effective cutting angle of 45°
  • Ductile cast-iron body; 139.7mm (5 1/2") long
  • Supplied with a 6.35mm (1/4") wide lapped A2 tool steel blade
  • Available in both left or right-handed
Specialised small joinery plane, ideal for cutting grooves, such as those used for small drawer and box bottoms. It also has the ability to cut rebates (grooves with one open side), as well as decorative beads. The compact, light weight design allows you to work closer to your projects for longer periods of time.
The Veritas Box-Makers Plough Plane features a 139.7mm (5 1/2") long ductile cast iron body, weighs 652g (1lb 7oz) and has a machined 45° blade bed. The grip has been sculpted to fit the hand for maximum comfort and can be used with one hand, if necessary. The ergonomic design of the fence makes it easy to keep it firmly in contact with the work. It can be adjusted to plough a groove up to 63.5mm (2 1/2") from the edge of your work and a small recess in the sub fence lets you make cuts narrower than the blade width. Features relieved edges to avoid marking the workpiece.
Large brass knurl knobs make adjustments fast and easy without the need for tools. A brass knob secures the blade from the side to ensure vertical alignment with the skate, and another holds it from the top to lock the depth setting. The depth of the groove or rebate can be easily locked in place up to a maximum of 96.5mm (3/8") deep.
Supplied with a 6.35mm (1/4") wide lapped A2 tool steel blade. Can be used with any Veritas Plough Plane blades from 4mm up to 10mm (1/8" up to 3/8") wide. Available in both left and right handed versions.
Made in Canada.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
