Veritas Miniature Edge Plane
952857
From £42.98 £35.82
2 Reviews
In Stock - Ready to dispatch
  • Fully functional 1/3-scale Veritas edge plane
  • Useful for fine trimming work up to 10mm wide
  • 60mm long body, 12.7mm wide A2 steel blade
  • Investment-cast stainless steel precision machined
  • Supplied in a French-fitted embossed leatherette box
  • Weight 45g
  • Made in Canada
This is a 1/3-scale version of the Veritas iron edge plane. It is a fully functional miniature. Useful for fine trimming work on thin stock up to 10mm thick, such as with small-scale boxes, it fits the hand well, making it easy to control under fingertip pressure. The 60mm long body and lever cap are machined, investment-cast stainless steel. The 1.5mm thick by 12.7mm wide A2 steel blade has a 25° bevel angle, and, like the original, is bedded at 12° and skewed at 30°. The blade position and depth of cut is easily set by hand. Supplied in a French-fitted embossed leatherette box, weight 45g. Made in Canada.
5.00 2
