This 75mm wide router plane not only looks like its full-size counterpart, it works like it too. Comfortable to hold and manoeuvre, it is ideal for hardware installation, fine inlay or intarsia work. It comes with a 3.2mm wide A2 tool-steel blade (hardened to HRC 60-62), positioned inboard for standard use or outboard for true bullnose work. The carefully machined stainless steel body has a ground and lapped sole. The sole encircles the blade for maximum registration to a workpiece and to bridge recesses for stability on narrow stock. The knobs are hardwood. A fine screw feed mechanism sets blade depth, whilst a knurled clamping knob secures the blade. Weight just 55g, supplied in an embossed, French-fitted presentation box.
