Veritas Mounting Plate Only for Dowel Former
504101
From £12.28 £10.23
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • 75mm diameter mounting plate has screw holes for permanent mounting
  • Solid steel 6.3mm thick
  • Requires Veritas dowel former insert
  • Metric and imperial inserts available
  • Made in Canada
The 75mm diameter and 6.3mm thick steel mounting plate has screw holes for permanent mounting (or use it over a dog hole). A range of interchangeable inserts snap securely into the plate and are available in metric and imperial sizes. The plate coupled with an insert allows you to make dowels of any length or species as you need them.
