Veritas Variable Angle Fence for Rebate Planes
102158
From £78.68 £65.57
  5. Half Star
4 Reviews
Low Stock - Ready to dispatch
  • Accessory for Veritas skew rebate or jack rebate planes
  • For accurate and consistent angles from 45° to 135°
  • Through-holes allow attachment of a wooden sub-fence
  • Use a tapered spacer for planing angles less than 45°
  • 275mm long made from aluminium and brass
  • Made in Canada
The Veritas Variable Angle Fence mounts onto the fence rods of the Veritas skew rebate or jack rebate planes. This variable angle fence locks firmly in position with brass collets. It will allow you to plane accurate and consistent angles anywhere between 45° and 135°. Set the fence using a square, a bevel, an angle gauge or directly on an angle you wish to match. The spring-loaded locking lever can be rotated out of the way if necessary. Through-holes in the fence allow you to attach a wooden sub-fence or tapered spacer for planing angles less than 45°. The fence is 275mm long made from aluminium and brass. Made in Canada.
4.30 4
