Woodcut Tools Bowlsaver Max 4 Light Guide
- Plan before you cut
- Takes the guesswork out of setting the Bowlsaver Max
- Light guide shows the path the cutter will take
- Quick and easy to set up and use
Woodcut Tools Bowlsaver Max 4 Tool Post - 30mmSpecial Price ÂŁ30.88 ÂŁ25.73 was ÂŁ51.48 ÂŁ42.90 Save ÂŁ20.60 ÂŁ17.17
Woodcut Tools Bowlsaver Max 4Special Price ÂŁ577.48 ÂŁ481.23 was ÂŁ769.98 ÂŁ641.65 Save ÂŁ192.50 ÂŁ160.42
Woodcut Tools Bowlsaver Max 4 Tool Post - 25mmSpecial Price ÂŁ30.88 ÂŁ25.73 was ÂŁ51.48 ÂŁ42.90 Save ÂŁ20.60 ÂŁ17.17
WoodSpur Torx Head Wood Screw Assortment (1,500 Pieces)Special Price ÂŁ24.98 ÂŁ20.82 was ÂŁ29.98 ÂŁ24.98 Save ÂŁ5.00 ÂŁ4.17
Axminster Professional Stainless Steel Metric Rule - 300mmSpecial Price ÂŁ2.68 ÂŁ2.23 was ÂŁ3.58 ÂŁ2.98 Save ÂŁ0.90 ÂŁ0.75
Axminster Professional Forged Flat Bar Clamp 200 x 80mmFrom ÂŁ15.58 ÂŁ12.98
UJK Level BoxSpecial Price ÂŁ19.98 ÂŁ16.65 was ÂŁ24.98 ÂŁ20.82 Save ÂŁ5.00 ÂŁ4.17
Watch where you’re going, the Woodcut Tools Bowlsaver MAX Light Guide shows you the path the coring blade will take, Before you begin cutting. The light guide is a great help when it comes to the best from your blank. The MAX light Guide is for the three bladed Bowlsaver. Setting up and coring is much easier when you can plan the cut exactly beforehand. the Bowlsaver Light Guide makes it easy to establish where the blade is going to cut the wood blank.
The Light Guide has a post, which attaches to the pivot bolt of the Bowlsaver. It has an arm that holds a light pen positioned in line with the cutter. The Bowlsaver guide has three holes, one for each blade.
EAN Barcode | 9421905382533 |
