Woodcut Tools Pro-Mount Bench Plate
109794
109794
- Use with the Woodcut Tools Pro-Mount Body & Tool Post
- Sturdy base enables you to work on a bench, table or any fixed surface
- Machined slots enable use on a milling machine cross slide or pillar and drill table
- Zinc plated stainless steel for long-lasting durability
- Sturdy platform and easily adjustable; work in comfort
Show more
Show less
The Pro-Mount Bench Plate is to be used with the Woodcut Tools Pro-Mount Body and Tool Post. The Pro-Mount Bench Plate will enable users of the Pro-Mount Body and Tool post to mount the stand on any surface. Designed with slots in the base, the bench plate can be mounted onto a bench, wall, a milling machine cross slide or pillar and drill table.
Simply screw this plate onto the thread of your Pro-Mount Post.
Made from Zinc plated stainless steel to ensure long-lasting durability.
Please note, the tool post is not included with this product.
EAN Barcode | 9421905382625 |
