Vitrex Power Max Tile Saw 560W 230V
- Smooth dust-free tile cutting
- Diamond blade cuts ceramic and porcelain tiles
- Versatile, make straight, angle and mitre cuts
- Extending table for larger floor tiles
- Water cooled, constantly recirculated
The Vitrex Power Max Tile Saw cuts tiles up to 30mm thick. The 180mm continuous rim diamond blade will slice through: ceramic, porcelain, slate, stone, marble, travertine, granite, quarry, terracotta and limestone. It’s powered by a 560W high torque direct drive motor ensuring a smooth and constant cutting speed. The Power Max is water cooled, with the water continuously recirculated for dust free operation.
The top features pull out extension arms, extending the top from 420mm to 560mm, to support larger floor tiles. The full length fence is easily adjusted for straight cuts, whilst the mitre fence allows you to cut tiles at an angle. The right-hand side of the table tilts at preset angles of 22.5°, 30° and 45° for cutting mitres along an edge. This machine will prove indispensable for anyone undertaking a large tiling job.
Blade Diameter | 180 mm |
Blade RPM | 3,000 rpm |
Bore Size | 16 mm |
EAN Barcode | 5011204608744 |
Max Depth of Cut @ 45º | 17 mm |
Max Depth of Cut @ 90º | 30 mm |
Model | WS560180 |
Nett Weight | 7.4 kg |
Overall L x W x H | 410 mm x 420 mm x 190 mm |
Power | 560 W |
Rating | Home Workshop |
Table Size | 410 mm x 560 mm (with pull-out extensions) |
- Standard Delivery* - Free
