Axcaliber Reverse Glue Joint Cutter Head
- Hard aluminium alloy body with high resistance to tensile and yield stress
- 2 solid tungsten carbide knives 50 x 18 x 2mm
- Suitable for manual feed
- Pins for the automatic positioning of the knives
- Supplied in a storage box
Axcaliber Knives for Reverse Glue Joint Cutter HeadFrom £113.88 £94.90
The most unique and important feature of this Axcaliber cutter head is its capacity to produce an almost indestructible glue joint quickly and without error. Ideal for shaping wide dimension panels, doors and furniture pieces. By accurately centering the cutter head to the wood, the upper and lower vertical cutting edges will cut equal proportions. Simply run one edge of the panel, turn the panel over, and then run the opposite edge - you will produce perfectly harmonized reverse cuts that match up to make flawless joints. Cutting diameter 100mm, bore size 30mm.
EAN Barcode | 5052511038473 |
This product is classified as a Make to Order product.
Delivery time is approximately 7 weeks.
- Standard Delivery* - Free
