Axminster M42 HSS Cobalt Drill Bits
- M42 high speed steel, 8% cobalt, tough drills for tough materials
- For use on alloy and hardened steels, cast iron, titanium and more
- 130° tip angle
Customers Also Bought
Precision ground metric drill bits made from M42 high speed steel bars with 8% cobalt achieving a hardness of some 63.5 - 65 Rockwell. The Cobalt allows the drill bits to hold their hardness at higher temperatures. Intended for use on alloy and hardened steels, cast iron, titanium and many other really tough, hard-to-drill, materials such as stainless steel. Perfect for home and production use. Available in a range of metric sizes. It is advisable to use coolant when appropriate. 130 Degrees tip angle.
- 130° tip angle
