Axminster Workshop Double Sided Tape
From £8.58 £7.15
  4. Half Star
9 Reviews
  • Graduated on both front and back of the blade
  • Wide deep curved blades
  • Rubber grip cases
  • Blade brakes
  • Available in 5 or 8 metre lengths and 25mm wide
  • Metric and imperial markings
  • Class 2 accuracy
Axminster Precision Tape Measures
As well as having all the features you would expect from heavy duty contractor's tapes - wide deep curved blades, rubber grip cases, blade brakes, etc., these two tapes (5 metres and 8 metres long, both 25mm wide) are dual marked imperial and metric on both front and back of the blade. The main advantage of this feature is to allow the tape to be used for marking lines as well as measuring, the curvature on the blade giving sufficient stiffness to enable a reasonably accurate line to be drawn along the tape. The floating end clips are secured by three rivets and protrude from both sides of the tape.
3.60 9
