Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Precision Bronze Squares with Metric Rule
  • Accurate, robust and stable
  • H-section bronze stock with hardwood infill
  • Stainless steel blades with matt chrome finish
  • Permanent 3-rivet fixing
  • EC class 1mm scale on both sides and both edges
  • Manufactured in accordance with British Standard BS3322/IS 4017
  • Accurate on both internal and external angles
  • Supplied in a foam lined box
  • Show More
NOW £15.95 - £36.95
Normally from £17.95
(£13.29 - £30.79 Ex. VAT)
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
The stocks are H-section bronze with a hardwood infill. The blades are stainless steel with a matt chrome finish. The blade sits in a slot cut into the H-section, permanently secured by three brass rivets. This metal to metal fixing method ensures accuracy as squareness is unaffected by changes in humidity that could affect a wooden stock. The hardwood infill makes this a more attractive tool. Manufactured in accordance with British Standard BS3322/IS 4017, the squares are fully tested to a tolerance of less than 0.01mm/10mm blade length, both inside and outside. The stainless steel blades feature a millimetre scale on both sides and both edges. The EC class 1 scale begins at zero on both the inside and outside edges. The bronze stock means these squares are heavier than a normal equivalent. However, they are robust and offer greater stability. Supplied in a foam lined box. A tool you can pass on to the next generation.
Promo
This product is on page 230 of the Axminster Tools & Machinery 2019/20 Catalogue.
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
