Axminster Professional AP2920B Bandsaw - 230V
108517
Special Price £1,002.98 £835.82 was £1,179.98 £983.32 Save £177.00 £147.50
  5. Half Star
41 Reviews
In Stock - Ready to dispatch
  • Large capacity up to 300mm max cutting height
  • Tension release lever for straightforward blade changes
  • Efficient, two point dust extraction via dual outlet
Great value for woodturners and cabinet makers alike
The AP2920B represents a fantastic capacity machine that can serve those with limited space perfectly. It’s a professional grade machine with features to suit both woodworkers and turners.
Buy with confidence
Large cast iron table
The 440mm x 540mm table gives maximum support to large workpieces that will glide smoothly on the cast iron.
Tubular steel frame & press steel doors
The AP2920B is built on a tubular steel frame for robust strength and reduced vibration.
Independent adjustable blade guide system
Set up quickly and easily, so you can focus on the task at hand.
300mm depth of cut
A generous depth of cut makes this bandsaw versatile enough for a variety of tasks, from cabinet making to woodturning preparation.
Cast iron blade wheels
355mm diameter cast iron wheels reduce vibration and maintain blade speed for a smooth and consistent cut.
Dual slots for mitre gauge
Two mitre slots either side of the blade are perfect for jig use. The AP2920B is supplied with a premium mitre fence with useful pre-set angle stops.
Rack & pinion upper guide adjustment
Easily adjust the upper blade guide with the rack and pinion rise and fall. There is also a tension release lever for straightforward blade changes.
Hi/lo auxiliary rip fence
The dual height rip fence locks positively; use “hi” for full support on heavy duty ripping and “lo” for safe close to the blade work.
High quality handwheels
The bandsaw’s hand wheels are well made in die cast aluminium for smooth adjustment.
How to get the best out of your AP2920B
Learn how to set it up for accurate cuts
Our experts show you everything you need to know, right through to making your first cut!
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
Shop 2,920 mm bladesRead our buying guide
  1. Axminster Professional AP2920B Bandsaw - 230V
Total:
£1,080.26 £900.22
Professional by name, professional by nature. The AP2920B floor standing bandsaw represents great value, whether in a busy workshop or for a woodworker looking for a larger capacity machine. The 1.7kW induction motor easily copes with the 300mm max cutting height. The 355mm diameter cast iron wheels with hard rubber tyres, add to the smooth cutting action.
The smooth ground, cast iron table tilts up to 45° and features mitre fence slots on both sides of the blade. The upper blade guide has rack and pinion rise and fall for ease of adjustment.
The rip fence locks positively and has a Hi/Lo auxiliary fence. ‘Hi’ for full support when deep ripping or ‘Lo’ when cutting thin section timber.
The quick tension release makes blade changing straightforward. Fully adjustable blade tensioning and tracking ensure precise cutting action.
Dual dust extraction is efficient via a 63mm outlet under the table linked to a 100mm outlet by the bottom wheel.
Supplied with a premium mitre fence with useful pre-set angle stops. Also supplied with blade - 2,920mm x 12mm x 6tpi.
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classifcation
These products are designed for frequent and extended use in professional environments, offering the performance and durability required for trade and workshop applications, without being intended for full scale professional or continuous use. They must be maintained and serviced annually. Guarantee is void when used for industrial use or part of a production line.
Learn more
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.68 41
