USE CODE: BLACKFRIDAY TO SAVE 10% SITEWIDE*
Axminster Workshop White Grinding Wheel 200mm x 25mm
AX1029066
AX1029066
- Sharpen high carbon and HSS tools
- Cooler cutting with less tendency to overheat the steel
- Cuts freely offering a fast result and clean finish
- 200mm diameter x 25mm wide, 5/8" bore
Axminster Professional Forged Flat Bar Clamp 200 x 80mmSpecial Price £11.23 £9.36 was £14.98 £12.48 Save £3.75 £3.12
Show more
Show less
White Aluminium Oxide grinding wheels are a preferred choice for general tool sharpening of high carbon and HSS tools.
Compared to general purpose grey grinding wheels, white wheels cut much cooler with far less tendency to overheat a tool’s edge (if you press hard enough for long enough you can still blue the edge).
These white grinding wheels have a medium hard vitrified bond with a medium structure. They are friable and cut freely offering a fast result and clean finish.
The wheels have a 5/8" bore
Bore Size | 15.88 mm (5/8") |
