Axminster Workshop AW200BDS Belt & Disc Sander - 230V
107680
From £189.98 £158.32
  5. Half Star
224 Reviews
Dispatching Soon
- Email me when available
Delivery
Free Standard Delivery*.
Dispatch estimate is within 2 weeks.
  • Motor - 550W, induction quiet, direct drive
  • Versatile sanding positions. belt being used in different positions
  • Integrated fan for improved extraction when used with extractor
  • Modern design and steel and cast construction
A welcome addition to many small home workshops
This Axminster Workshop Belt & Disc Sander enables the shaping, sanding and profiling of wood to be carried out easily and safely.
Buy with confidence
Efficient dust extraction
A fan built into the dust outlet makes extraction a breeze. When connected to an extractor, almost 100% of the dust can be removed.
Multi belt position
The belt sanding platen can be positioned vertically, horizontally or at any angle in between.
Sand compounds and mitres
Both the belt and disc tables incorporate a slot for the mitre fence, allowing bevel and compound angle sanding. Both sanding functions have a well-sized work table, which pivots from 0° to 45°.
Quiet running
Both the belt and disc are driven directly from the 550W induction motor, making it quieter than a drive belt system.
Excellent guarding
Well fitting guarding not only makes this a safe machine to use but also helps improve dust extraction.
Cast iron body for minimal vibration
The main body is cast iron helping to reduce vibration for a more comfortable woodworking experience.
  1. Axminster Workshop AW200BDS Belt & Disc Sander - 230V
Total:
£217.42 £181.18
The AW200BDS is a powerful combined 100mm belt and 200mm disc sander. The belt and the disc are driven directly from the motor spindle. As a consequence the machine is much quieter, there are no fiddly drive belts to worry about and does not suffer from a loss of power caused by a drive belt. Both functions feature cast worktables, which pivot from 0° to 45°. A mitre fence is supplied for bevel and compound angle sanding.
The belt sanding platen can be used vertically or horizontally or anywhere in between. The machine has a 63mm extraction outlet. A powered fan in the dust outlet port helps produce an airflow around both the belt and disc. When connected to a suitable vacuum extractor almost 100% dust extraction can be achieved. The main body is cast iron, which absorbs vibration and has locating holes with rubber grommets for securing this sander to a workbench.
The AW200BDS is supplied with a belt and hook and loop abrasive disc. There is a wide selection of abrasive belts and discs available.
Please note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Please note, if you require an EU plug, please ensure you purchase 113504
Warranty Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed and intended for those who require equipment for more regular, but not continuous, operation. They must be maintained and serviced in line with our schedule; otherwise guarantee may be void.
Learn more
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.58 224
