Axminster Workshop AW205WL Woodturning Lathe - 230V
- Compact lathe with the capacity for goblets, boxes, small bowls
- Variable speed; cast iron construction for trouble free operation
- Portable enough to take along to a craft fair or demonstration
All the features to fulfil the needs of the keen craft woodturner
If you’re passionate about woodturning but short on space, this lathe could be the answer. The size and weight of the AW205WL make a conveniently portable or easily stored lathe. It has all the features required to fulfil the needs of the keen craft woodturner; cast iron constructions, variable speed drive and all the essentials included. Ideally suited to pen making or projects such as pepper mills and bottle stoppers, this lathe is perfect for those looking to undertake craft demonstrations or those with limited workshop space. Good things come in small packages, especially when it comes to the Axminster Workshop AW205WL Woodturning Lathe.
3 Year Guarantee
Conveniently compact
Weighing just 21kg total and perfectly compact, the AW205WL is great for smaller workshops and craft fair demonstrations. You have the ability to pack up your lathe and store it away, or easily transport it.
Supplied with genuine Axminster Woodturning centres
The lathe is supplied with genuine Axminster Woodturning Four Prong Drive and Revolving Tailstock Centres; both designed and manufactured in Axminster, UK.
How to get the best out of your AW205WL
Learn how to set it up for the best results
Our experts show you everything you need to know, right through to mounting your first blank!!
If you’re passionate about woodturning but short on space then this lathe could be the answer.
The size and weight of the AW205WL make a conveniently portable or easily stored lathe. It has all the features required to fulfil the needs of the keen craft woodturner. This lathe is ideally suited to pen making or projects like pepper mills, bottle stoppers etc. and many other other craft fair items. This compact machine has the capacity to turn goblets, boxes and bowls up to 200mm diameter. Small and neat it won’t hold you back, there’s plenty of power in the motor and the variable speed is a huge benefit. The machined cast iron construction ensures smooth, trouble free operation and years of woodturning pleasure. Supplied with 115mm and 175mm long tool rests.
Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
Distance Between Centres | 330 mm |
EAN Barcode | 5052511125227 |
Headstock Taper | 1 MT |
Lathe Speed | 750 - 3,200 rpm |
Max Diameter over Bed | 205 mm |
Model | AW205WL |
Nett Weight | 20 kg |
Overall L x W x H | 730 mm x 150 mm x 310 mm |
Power | 300 W |
Rating | Home Workshop |
Spindle Thread | 1" x 8 tpi |
Tailstock Ram Travel | 35 mm |
Tailstock Taper | 1 MT |
Tool Post Diameter | 12 mm |
Voltage | 230 V |
- Standard Delivery* - Free
