The Axminster Workshop No. 9. 1/2 Block Plane is a well-made plane, delivering excellent features at great value. With a cast iron body that has been accurately ground and finished, yet weighing only 950g (2lb), it is one of the most useful planes in the woodworker's armoury.
This plane has an adjustable mouth, making it suitable for fine or coarser work, and it features a micro depth adjustment with lateral blade control, for complete control of the depth of cut. The No. 9.1/2 Standard Angle Block Plane has its blade seated at an angle of 20°. The blade is used bevel-up, giving an ideal cutting angle for all manner of trimming and general small planing jobs. The sole is 155mm long with a 41mm wide blade, and comes with a 25° bevel. The blade only requires honing before use and it will be possible to put a 30° micro bevel on the edge in less than a minute. So, this plane will be earning its keep in your workshop in no time.
